F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-20-2004, 11:33 AM
Trans flush vs. partial drain & fill
I've heard that it is not good to totally drain and fill the new electronic trannies because they actually need some of the residual particles from the fluid that remains in the torque converter to prevent slipping. This is from an auto repair shop owner. A buddy of mine did the full tranny flush and sure enough had problems within a month. What do you guys think? I don't like the thought of leaving old fluid in, but I also don't want to cause problems.
Old 06-20-2004, 12:23 PM
Vehicle: 1999 Ford F150
How long was it since your buddy last changed his transmission fluid?
If his tranny was flushed then I assume the filter was not changed...
http://www.filtercouncil.org/techdata/tsbs/98-2.html
The "residue particles" story sounds like bullcrap to me...
Larry,
1999 Ford F150 Lariat Flareside Extended Cab, 4x4, 5.4L engine.
Old 06-21-2004, 05:15 PM
Vehicle: 2001 Ford F150
The tranny flush is not always a good thing because, if you've ever opened up a transmission with 40K+ miles on it, you'll realize there is a significant amount of clutch pack material as well as some metal. Not piles, but a coating on the bottom. This, as well as the crud that is in the filter, gets "flushed" back into the valve body. If you decide to flush, it is best to clean the pan and replace the filter first.
We are pretty lucky with our Fords because we have a drain plug on the torque converter (I'm pretty sure all of the 97- 04 models do anyway). This allows us to drain the converter and pan at the same time, removing 90% of the old fluid. If you drain out your cooler lines and let it drip for a little while, you'll get almost all of the old fluid out. Great time to clean the pan and install a drain plug!
Do a search here for complete drain and fill instructions.
2001 F150, Black, Shortbed, Regular Cab, 4.2L V6, Auto, 3.55 gears, 4x4
Modified intake and throttle body, 265/75R16 Toyo All Terrains, Spicer greasable U joints & Moog ball joints, Delta toolbox, trans cooler and guage, Magnaflow muffler, Reese Class III hitch.
Old 06-22-2004, 09:31 AM
Vehicle: 2002 Ford F150
Quote:
Ford eliminated the drain plug in August, 2001.
Old 06-22-2004, 10:11 AM
Vehicle: 1997 Ford F-250 LD
I've drained my torque converter and dropped the pan twice in 114k miles. Trans is still working great and there was very little debris in the pan each time. The magnet had about 1/16" coating of particles on it this last time.
My torque converter has the drain plug, pan doesn't. Wish it did.
Old 06-22-2004, 12:38 PM
laneman- That's a new one. Is there documentation?
casey_1- No drain plugs =
Iggy- The first time I drop any transmission pan, I install a drain plug. It's very simple and saves future ATF facials.
Old 06-22-2004, 02:55 PM
Quote:
I bought mine in January of 01, so I guess I lucked out. That really sucks about the TC drain plug. Good to know for the future. Thanks casey!
Old 06-23-2004, 12:07 AM
I had mine flushed at 30,000 miles, and have not had any problems. I do plan on dropping the pan and changing the filter at 35,000 anyway just to be safe.
Be insensitive......Tell the truth !!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
