F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-20-2004, 01:25 AM
Vehicle: 1999 Ford F150
Where's your clutch grab?
Hey guys...I just got a 99 F150 4.6 5spd last week. Its got 52K on it and is in pretty much great condition. One thing though...the clutch pedal is almost all the way out before the clutch actually engages. It doesnt feel like its slipping or anything, so I dont think its bad...I know these are hydraulic systems so there probably is no adjustment right?
Any thoughts?
Old 06-20-2004, 06:42 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
You should not have to press your clutch pedal down more than 1/3 of the way for it to be completely disengaged. More than that and your clutch is starting to wear out or there is air or moisture trapped in the system. Start by bleeding the system and see if it moves the pedal up.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 06-20-2004, 06:55 PM
OK thanks.
Old 06-21-2004, 10:43 AM
Vehicle: 2001 Ford F-150
...so should one not press the clutch all the way to the floor every shift?
Old 06-21-2004, 06:39 PM
I dont put it all the way to the floor, since it disengages at the slightest touch. But that doesnt mean I'm right....
Old 06-21-2004, 09:02 PM
JMC JMC is offline
When I drive normally I press it all the way. This will insure that it is completely disengaged every time. It is easier on the leg muscle too.
JMC
Old 06-21-2004, 11:26 PM
I dont typically push my clutch to the floor unless I'm starting the engine (no choice) or if I'm experiencing the problem of it not going into any gear at all. This happens more often than not. Am I at risk of shortening the life of the clutch by not going to the floor all the time???
Old 06-22-2004, 12:37 AM
JMC JMC is offline
It will not hurt the clutch unless you do not push it to or past the full disengage point. It is just easier on the leg if you push the clutch pedal all the way to the floor.
JMC
Old 06-24-2004, 05:13 AM
you can't push it too far,unless you press it so hard you break the pedal.so i always push it to the floor just to make sure its completely disengaged.you're not gonna damage the clutch by not disengaging it all the way but you will tear up the tranny by doin that
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
