F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-29-2004, 08:59 PM
Vehicle: 1994 ford f150
mercon v in e4od??
I need to change fluid in trans. Keep hearing that i should switch to the mercon v instead of regular mercon. Has anyone here done this? Any problems? Is all mercon v the same or are some brands better than others? Mobil 1? Thanks. Its in a 94 150 with 60k.Just got the truck and not sure of the maint. it received. Trans. does have remanufactured sticker on the side with some bar codes. Would this be a ford reman. ? Noticed a cork gasket hanging out around the pan edges.
Old 03-29-2004, 09:47 PM
Vehicle: 2002 Ford F150
Ford says to not use MERCON V in an E4OD.
I use Mobil 1 synthetic ATF. It has a MERCON rating, and not a MERCON V rating.
Old 04-04-2004, 04:04 AM
Where does ford state not to use mercon v in e4od trans. and when was it stated? Thanks.
Old 04-06-2004, 11:56 PM
Ford has a TSB that lists what fluids are used in what transmission. That TSB says to only use MERCON in the E4OD. I think the TSB number is 01-15-7.
Old 04-07-2004, 03:29 AM
Vehicle: 2005 Ford Mustang
Quote:
It's in your owners manual if you have a truck that was built after MERCON V was first sold, it's very bad for the E4OD/4R100.
G
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
