hollywood;
The problem with parking brakes is that if you use them occasionally, they will often stick instead of releasing completely. If they are hanging up, the best thing to do is replace the cables. I have never had any luck trying to lube the cables on any vehicle I have had. It works for a little while and then they stick again. The nylon sheath inside the cable gets worn through and the inner steel cable and outer steel sheath rub together, rust and stick. Once that happens, it is difficult to clean out the rust which is binding the cable. I replaced my originals with aftermarket parts about 1-1/2 years ago and they are starting to stick again. It would have been better to replace them with Ford parts because they lasted about 4 years. I hope this helps, GlennMc.
