F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-28-2004, 12:38 AM
Vehicle: 1993 FORD BRONCO
B-w 13-56 Transfercase Problem
I have a 93 bronco with 5.0 E4OD and push button 4x4. It will not go into four high or low. I can see it pulling a load on the electrical system(lights dim), but will not lock into gear. Also the trans seems to shift early into drive and OD. Seems to shift ok into Second gear. This is two different problems, but does anyone dealt with this before. Thanks for any info u can give.
Old 03-28-2004, 06:46 PM
Vehicle: 2002 Ford F150
I think you need to clean and repack your front locking hubs when this happens.
Old 04-16-2004, 12:42 AM
FOUND PROBLEM. TOOK OFF THE SHIFT MOTOR ON TRANSFERCASE AND TOOK IT APART. PUT IT BACK TOGETHER AND IT WORKS. GUESS IT WAS JUST STUCK.
Old 04-16-2004, 06:23 PM
Vehicle: 1992 Ford F150
93EBBRONCO...
Use the 4wd about once a month, and you shouldn't have any more problems. The shift motor tends to get sticky if left alone. Had this problem a few years ago, and haven't had it since.
Also, you can search on this site for more info...lots of posts about this problem.
Good luck!
Tom Kenney
tjkenney@bearcomp.com
My truck, Sparky, is a 1992 F-150 XLT, 4x4 SC ShortBed, 302 EFI, E4OD, 3.55 LS, silver-on-black two-tone
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
