F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-12-2004, 01:18 PM
Vehicle: 1997 Ford F-150
Cant shift out of park
Has anyone had this problem???
I start my truck and the shifter on the column seems to be locked up - kinda like I don't have my foot on the brake to shift into drive.
Then all of a sudden it shifts after I jiggle the shifter a little - how hard is it to fix???
Someone please - I have a feeling before too long I won't be able to shift it at all.
Old 03-12-2004, 10:23 PM
H_1 H_1 is offline
Yes.
Had something very similar happen last summer. Here's what we found.
We have a 97 Expedition with the auto tranny. The lawyer switch prevents shifting out of park unless the brake is pressed. This switch is connected to the brake pedal's arm. Over a period of years, the wiring connected to this switch frayed, and eventually broke. At that point, I could not shift it out of park. I might have directed some unkind words towards the interns that designed this component at that point.
In theory, although I'm sure this is illegal and so should not be done under any circumstances, the fuse controlling said interlock could be looked up in the manual and pulled. But that would leave you without a brake light. Of course, if the wire's broken you don't have one anyway.
A fix involves a trip to electrode hut and ten minutes with some blade connectors, electrical tape, and a crimper. If you should happen to pull the switch, the fix should become apparent. If you have trouble pulling the switch, it might be time to call for reinforcements.
Good luck!
Old 03-13-2004, 01:18 PM
Thank you H_1 - I will give it a shot -
Old 03-14-2004, 08:43 AM
You were right - thats exactly what it was - the Brake on off switch - as ford calls it.
I replaced it last night and low and behold - life is good again.
Thanks again.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
