F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-07-2003, 07:25 PM
Vehicle: 2000 Ford F150
Send a message via Yahoo to Kegenuts
Question 4R70W Output Shaft Moves Side to Side?
I have a driveline vibration that I've narrowed down to the output shaft/slip yoke. I eliminated the rest of the driveline as the problem by disconnecting the driveshaft and running the tranny with just the slip yoke installed. With the entire driveline disconnected except for the slip yoke, there is a vibration at 30-35 MPH and 60-65 MPH (exactly like the vibration when the truck is going down the road). At first, I thought it was due to a worn extension housing bushing because I could move the slip yoke side to side in the extension housing. I installed a new bushing, but the slip yoke still has about the same amount of side to side movement. While I had the extension housing removed, I noticed the tailshaft of the transmission also moves side to side which doesn't seem right.
Does anyone know if side to side movement of the output shaft is normal or if there is a runout spec that I can compare to? Any help is greatly appreciated!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
