F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-25-2003, 11:36 PM
Vehicle: 1997 Ford F-150
Manual Transmission Swap
Is it possible to swap a heavier-duty transmission in for the 5-speed that came in the 1997 F-150. I have a 4x4 F-150 with the 4.6L and would like to tow something heavier than the 2700 pound towing capacity limit with the factory transmission.
Thanks,
tt
Old 08-26-2003, 08:04 AM
Vehicle: 2007 Ford Edge
Hey! Welcome to the boards.
I can't really help you on this one, as I'm not aware of anything that can be done to up the tow rating. I think the 5.4 would accept the manual out of a Super Duty, but I don't think the 4.6 would. You could upgrade the clutch. I believe that is one of the major factors in the low tow rating.
I too would like to upgrade this manual transmission. I'm looking for better performance though. I would like to find a way to use a T56.
Some one might know so keep checking.
Good luck!
Tom
'07 Ford Edge
Ford says the Edge is a truck/SUV.
Click here to see the Ford trucks that I've owned
Click here to see the newest pics
Old 08-28-2003, 01:46 AM
Vehicle: 2004 Ford F-150
I have been trying to figure out some way to replace that POS transmission in my 99 4WD for years and have found nothing yet. You would think that there are standards that transmission manufacturers build to and that something else besides the Mazda tranny would fit.
LTDC
04 F-150, ext cab, 5.4L, 4WD FX4, K&N Filter, Line-X, 2" Level Kit
Old 09-04-2003, 08:25 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
The tranny from a Cobra R will bolt up. The tranny from a 5.4/6.8 SD will bolt up.
There are companies that are fitting the TREMEC to the Mustang. Your flywheel will have to be closely looked at. If you use the ZF from a Superduty you will have to make sure your engine is a Windsor. You have to use the flywheel & pressure plate from a SD. The input shaft on the ZF is 1 ¼ inch and the clutch is 12 inches in dia. The input shaft on the Mazda tranny is 1 1/16 inch and the clutch is 11 inches in dia. Unfortunatly the Flywheel from a Romeo engine has 6 bolts and the Windsor has 8 bolts so the SD flywheel will not fit on the Romeo.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
