F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-25-2003, 11:11 AM
Vehicle: 1999 Supercharged Ford F150
Question Flex Plate or Converter for Lightning swap
Will be installing a 2000 Lightning (L) engine/supercharger (only) in my 99' F-150 4.6 with the 4R70W trans.
It is my understanding that the L engine has an 8 bolt flex plate with 6 holes for the L torque converter. My 99' F150 4.6, supposely has a 6 bolt flex plate with 4 bolts for the torque converter. I need to bolt the L engine up to my 4R70W trans. Which of the following do I do:
1. Use only 4 of the 6 holes on the L flex plate and bolt the flex plate to my 4R70W torque converter (are the holes configured in a pattern that will allow this?); or
2. Find an 8 hole flex plate with 4 holes to bolt up my 4R70W torque converter (if so, what model flex plate should I look for?); or
3. Attach a L torque converter to my 4R70W trans. and bolt the L torque converter to the L flex plate.
Thanks for any assistance.
Old 08-26-2003, 01:16 AM
Vehicle: 2005 Ford Mustang
4) get a 4R100 with a 6 bolt converter.
A 4R70W would have a short and unhappy life behind a S/C 5.4. The 4R100 had to be beefed up for that motor, even a regular 4R100 won't last behind it.
G
Old 08-26-2003, 12:16 PM
Thanks Factory Tech for the tech support.
The problem with using the lightning transmission is that, I would have to change the wiring harnesses and pcm and have my truck towed to a ford dealership to have the PATS system re-programmed, just so that I could use the ignition key.
I was hoping I could get an f150 8 bolt 5.4 or 4.6 windsor flexplate with only 4 bolt holes for the 4R70W torque converter. Then, if it all worked, I was going to look for a re-built 4R70W that could handle the lightning engine torque or get a "lower torque multiplying" torque converter........what do you think?
Note: You can get an 8 bolt flexplate with 4 bolt holes for the f150 4R70W torque converter.
Old 08-27-2003, 04:30 AM
All 4R70Ws are 4 bolt, and you can get a 5.4 with a 4R70W so it's shouldn't be a problem getting a flexplate. I'd try junkyards, they're not uncommon.
I still think you'll kill the tranny, while you're at a junkyard, look at a 4R70W and then look at a 4R100, the one that looks like a toy in comparison is the 4R70. Really, the Lightning model is a beefed up 4R100, stock.
G
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
