When you get the stock one off, there are several bores in the case, the one with the snap ring is the 1-2 accumulator, remove the snap ring and the piston, there are several springs in this bore, discard them all. Put the 2 red springs in, one inside the other, then the piston, then the green spring and then the cap and snap ring.
On the 2-3 accumulator, remove the "bottlecap" , put the white spring inside the OEM spring and replace the bottlecap wiht the one proivided, this is very important, use the bottlecap I sent, this just pops in.
Then replace the valve body, after swapping the solenoids from the old one.
That's it.
G
