F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-19-2003, 12:08 AM
Vehicle: 2004 Ford F150
Send a message via AIM to SVTErick
How many quarts of ATF?
im going friday to Ford to buy some Mercon V ATF and Motorcraft 5w20. i know ill need about 6 quarts of engine oil, but how many quarts of ATF should i buy? i really have no clue. also will i need a new filter. thanks
Old 08-19-2003, 02:45 AM
Vehicle: 2007 Ford F150
What transmission do you have?
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
Injection is nice but ide rather be Blown!!!
Old 08-19-2003, 10:48 AM
i have te 4R70W, ive been told 7-10 and then ive been told also 13-14! will the Ford parts people know when i go in to buy it?
Old 08-19-2003, 12:12 PM
Are you just draining the pan and the filter?Is your truck pre 2000?If it is you have a drain plug on the converter and if you drain that along with the pan you will need 12-13 quarts.If its just the pan 5 quarts are safe to get.But,why are you going to Ford to get the oil and fluid?Wal-Mart sells the Motorcraft 5w20 for $1.77 a quart.Motorcraft filters are $2.64-$2.97 there too.And the trans filter and fluid is cheaper at Autozone.Just trying to save ya some money.Good luck and keep us posted!
Old 08-19-2003, 10:31 PM
thanks for the money saving tips dude! Wal-Mart it is!
OK im going to be installing a new Factory Tech valve body. im guessing this involves me draining everything?
also do you know how much coolant ill need, b/c im going to change that also.
Thanks!
Old 08-20-2003, 01:28 AM
What motor do you have? You know,you should go to your profile and where it says signature put in the specs of your truck,like mine are in my signature.That way when you ask a question people will reply quicker knowing what you drive.
Old 08-20-2003, 01:51 AM
i got the 4.2, 4R70W
Old 08-20-2003, 01:54 AM
well i just made a profile, but as you can see it doesnt show up! anyways.
Old 08-20-2003, 01:55 AM
2001 Auto 4.2: Airraid intake, Flowmaster 40's, 4.10 gears, ported/polished TB, FTVB, cooler, E-fans, 4.0L Perf. headers, 180* t-stat, pulley, Superchip flip chip, Denso plugs, JBA wires, 3/4 drop, SS styling.
Soon: torque converter, 1.8 RR, 207/215 cam, CNC heads, t-lok
Those are my mods.
Old 08-20-2003, 02:59 AM
MiamiV6,is that you?
Old 08-20-2003, 10:55 AM
yea how did you know!
Old 08-20-2003, 12:47 PM
Coolant capacity; 4.2 V6- To get 85-90% of the old coolant out,ide pull the block drains and lower ratiator hose.You can use tap water to flush,but ide recommend using distilled water with the antifreeze fill.Dont forget the radiator drain valve at the bottom of the radiator!
with a/c= 17.3 quarts
with out a/c= 15.9 quarts
both 50/50 mix
You posted the same question on Talleys site.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
