F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-06-2003, 04:17 PM
Vehicle: 2004 Black Lightning
tranny oil
Is Dextron III with a Mercon friction modifier ok in the 4R70W tranny? I've seen Dextron III/Mercon labeld together on the same container.
Old 08-07-2003, 09:40 PM
Vehicle: 1999 Ford F150
First off you really need to be running Mercon V in your tranny unless it's pre '98 vintage. As far as additives, can't say. Wy bother. There are plenty of Mercon V fluids out there.
99, XL, SC, SB, auto, 4.6L, 3.55LS 2wd.
http://home.att.net/~neilwood.pe/wsb...ome.html-.html
Old 08-11-2003, 04:08 AM
I agree. A local tranny guy said that is what he puts in the transmisions he services?? I changed the fluid myself and put in Mercon V.
Old 08-17-2003, 10:28 PM
Vehicle: 1995 Ford T-Bird
Send a message via AIM to JustinH
Mercon V is the fluid of choice in ANY 4r70w transmission.
Period.
Old 08-17-2003, 10:43 PM
Registered User
Quote:
Period.
JustinH
It wasn't until late 97 early 98 that Ford started putting Mercon V in the trannys. Look on the trans dip stick, it should tell you to use Mercon or Mercon V.
When I changed mine about 6K ago, I put in Castrol Mercon/Dextron III, and no problems.
Old 08-18-2003, 01:56 AM
Vehicle: 2005 Ford Mustang
Adding a friction moidifier to MERCON makes it MERCON V, most tranny shops just stock one kind of fluid, and if they need MERCON V they add the modifier. Any 4R70W can be refilled with MERCON V, although they originally came with MERCON, but don't put any modifier in a 4R100, it only takes MERCON, never MERCON V.
Hope this helps,
G
Old 08-18-2003, 07:55 PM
Yes you are right the earlier 4r70w's came with mercon V from the factory.
There is a ford TSB out that recommends Mercon V in all 4r70w's for torque converter shudder.
Regards,
Justin
Quote:
Originally posted by mims
JustinH
Old 08-18-2003, 09:09 PM
Vehicle: 2008 Ford F150 4x4
What does the Ford dealers put in?
I talked to a number of places around town and they all used the mercon fluid with a modifier. That's not what I wanted, so I went to ford.
None would put synthetic in. If I wanted to use synthetic I had to argue just to be able to buy my own fluid and pay half price for the change using the fluid I supplied.
I expected that Ford was using a Mercon V fluid.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
