F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-02-2003, 01:00 AM
Vehicle: 1998 Ford F-150
5 Speed Upgrade
I'm bringing the truck to tranny shop this month for a clutch and a tranny rebuild (98 4.6/ 4x4). The tranny has shifted poorly since I got it at 30,000miles and has slowly gotten worse, esp the 1-2 shift where it likes to grind. The clutch also started slipping a little this year (too many drag-style launches). Time for action! Does anyone have any advice or instructions I should tell the mechanic? Any upgrades available? And has anyone heard about that Hurst shifter?!?
PS Has anyone else experianced the grinding when downshifting and hitting bumps? Is that all these transmissions do- GRIND?
Gibson Cat-Back, K+N Gen II, Performance Distributers coils & wires, Superchips BlueChip, HyperTech Thermostat, Helwig Traction Springs, Eaton Posi, Nitto 305/60 18s, Blau 4x6s with 75x4 Profile amp, and self-designed and installed graphics.
Speed Kills (small furry animals)
Old 08-02-2003, 01:12 AM
Vehicle: 2000 Ford F-150
yes this is about all this tranny does is grind it is a piece of ****
Old 08-03-2003, 12:02 PM
Vehicle: 2007 Ford F150
I have 38,000 miles on my 5 speed never had a problem with it grinding. I also drive it like a truck where you can not just slam the gears, or speed shift. It wasn't designed that way and its not a performance transmission. I believe as long as you drive it like a truck, because it is a truck you should have no problem at all.
Old 08-03-2003, 03:16 PM
Honestly, I feel I do drive it like a truck. I will not, however, drive it like my grandfather's Caddy! I guess a 'Truck' means different things to different people.
Old 08-03-2003, 06:20 PM
Send a message via AIM to prizmcreations
Just got a Centerforce Dual Friction for mine, supposed to hold 90% more than OEM. I've ran these in everything from a 12 second Mustang to a Toyota w/38.5" tires, and never had a problem. I'm very happy with how well they work, they don't even cost that much more than an OEM replacement, just find someone willing to put it in for you, even a newer truck can be tricky with the torsion bars. Less slip, it's either in or it's out, for these trucks the counter weights are on the inside rather than the outside. Also as far as the grinding, change your ATF (yes I know I said ATF, that's what's in most manuals now) to a high quality ATF, it will take a drive or two, but it will improve the grinding. These Mazda transmissions are notchy from the start, but this does help. I'm figuring on changing mine at least once every two years.
Just my 2 cents.....but from experience
98 F-150, 4X4, manual trans, XL, longbed, 4.6, 3.55 gears, dynomax camaro muffler, K&N filter charger, Hypertech III, Cross drilled/vented rotors, XLT rims, 265/75R16 AT tires, grill guard, nerf bars, ARE cap w/full rear door, aftermarket tach, Centerforce dual friction clutch, soon to add HD 98' F-250 springs and extendable towing mirrors (like the Super Duties).
Chris Wildy
Prizm Creations
Old 08-10-2003, 01:04 AM
Vehicle: 2004 Ford F-150
Yea, this tranny is a POS. Sometimes mine is almost impossible to get into 1st gear. I am going to break or bend something one of these days - probably break my hand against the dash when it does finally go into 1st gear.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
