F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-31-2003, 10:44 PM
Vehicle: 2008 Ford F-350
Angry Shuddering / Bucking problem
I have a shuddering problem when off the throttle at all speeds. I can actually get the whole truck to buck by stopping the vehicle at a slight incline, putting it in first gear, release the brake w/o applying any throttle, it will either start bucking then or I may have to put it in 2nd gear, then the whole cab starts shaking. This is between 2 and 5 mph. I have it at Ford now, and just got a call saying that there is nothing they can really do about and to come pick it up. Well, I am going in tomorrow to talk with the service manager about replacing the torque convertor or trans. I had this problem since new and had it in the shop at least 8 times for the same problem. If they won't fix it, I will lemmon law it. I just didn't want to go through the hassle of it. If anyone knows anything about this problem or something I can or Ford can do to fix, please let me know. If you want to know what Ford did about it so far, its NOTHING, 3 different dealers.
Old 08-13-2003, 08:28 PM
Vehicle: 1994 Ford F150
This happened to my truck with an AODE 94 F150 under warranty and it turned out to be the torque converter. I'm having the same problem now between 1-2 shiffts and plan on changing the converter again. Of course I have 150k more miles since the original shuddering.
Old 08-17-2003, 10:34 PM
Vehicle: 1995 Ford T-Bird
Send a message via AIM to JustinH
the cure for converter shudder in the 4r70w's is clean fluid, and that fluid must be Mercon V fluid.
It has cured many a shudder that I have worked with, everything from mustangs to 95 thunderbirds.
If you put clean fluid in it, and it still shudders then you need a new converter.
JH
Old 08-20-2003, 01:42 PM
Smile
Ok, I took it back to the original dealer and they finally repaired it. They replaced the torque convertor, transfer case, and trans shaft. It fixed the bucking problem and I also my rough idle. I had checked the fluid before and it was nice and clean. Also since it's a 2001, it came with Mercon V. Anyway, I would assume it has been changed now . Thank you for your replies.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
