F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 04-01-2003, 06:38 PM
Vehicle: 1993 Ford f150
transmission cooler
I have an E40D automatic transmission w/overdrive on my 1993 f150, extended cab, 8cyl, 5 liter, 3.55:1 rear end, 4x4. I'd like to install a temp gauge to monitor the tranny while I haul a 3500 lb camper. Any suggestions what brand gauge I should buy and exactly where I should install it to get the most accurate read?
Old 04-03-2003, 09:59 PM
three options for the sender..
i dont know exactly on the e4od but on the 4r100, on the drivers side above the shift linkage is a plug, the sender will thread right in....
second is to cut the metal line leading out of the trans to the cooler and splice in a "T" with compression fittings and the sender in the "T" part...
and third is if the plug is not there try the pan, next fluid change drop the pan and get the sender threaded into it...
these also go from most accurate on down IMO...
jim
A couple more PICS....
http://www.f150online.com/galleries/...y.cfm?gnum=306
Old 04-04-2003, 08:30 PM
Vehicle: 1997 Ford F150 4x4
Auto Meter gauges are nice and you could get a pillar setup with two gauges one for tranny temp, one for coolant temp. That's what I want to do I just need to figure out exactly which gauges and pod i want and need to work. I will probably go thru www.jegs.com
Richard D.
While your here check out my gallery:
http://www.f150online.com/galleries/....cfm?gnum=2479
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
