F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-25-2003, 01:16 PM
Vehicle: 1997 ford f150
e40d vs 4r70w or swapping them
which transmission is better e40d or 4r70w? I am pulling a 5.4 v8 motor out of a wrecked 98 expedition to replace my knocking 4.2 v6 in my 97 f150. The expedition has the e40d and 4wd but my f150 has the 4r70w with 2wd. Any body have any suggestions? Will the 4r70w bolt up to the 5.4 motor? can I change the tailhousing reasonably on the 4wd trans to put in my 2wd truck?
Old 03-25-2003, 04:38 PM
Vehicle: 2002 Ford E350
You can easily change the tailhousing to a tailhousing from a 2wd 4R100. The tailhousing from the 4R70W won't fit.
You'll also need to change the output shaft. That involves a total teardown of the transmission.
I don't think the 4R70W from a V6 will last very long behind the 5.4L.
Make sure to change the PCM and all the wiring, too. If you mix and match transmissions, wiring, and PCMs you'll end up with something that does not work.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 03-25-2003, 05:14 PM
Vehicle: 2005 Ford F150
4r70w's are behind most 5.4l's, including mine.
Old 03-25-2003, 05:24 PM
The 4R70W behind the V6 has less clutch plates and some weaker parts than the 4R70W behind the 5.4L.
Mark
Old 03-26-2003, 12:26 AM
Thanks for the info Mark
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
