F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-31-2002, 09:32 PM
Vehicle: 1994 Ford XL
I can't get my truck out of park
I went in the store and i came back out to leave and i couldn't get my truck out of park.I had to crawl under the truck and undo the linkage and put it in gear while the e-brake was on,i also noticed that i didn't have ant brake lights,or turn singals.Plus my airbag light comes on and flashes,and the antilock light comes on now.Thanks in advance for any help.
Old 12-31-2002, 11:10 PM
Vehicle: 2003 Ford F150
brake switch fuse...
then the switch itself...then the wiring at the connection to the switch,look closely because the wire will break where the connection is crimped on....everything else is coming on because the contact in the column is still telling the ECM that its in park and your moving so it,s freeking out....disconnect the battery to reset and you should be fine
Old 12-31-2002, 11:59 PM
Vehicle: 2001 Ford F150
Send a message via AIM to GearHead_1
What Texford said. Check the wire going into the brake light switch. These wires break.
My Gallery
Old 01-01-2003, 03:11 AM
Vehicle: 2002 Ford E350
The release on the shifter is tied into the brake light switch. If you don't have brake lights it won't shift out of park.
If this happens again there is a way to get it out of park without crawling under the truck. Turn the key one detent forward. Not enough to turn the truck on. Then shift to neutral to start the truck.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 01-01-2003, 12:20 PM
Vehicle: 2002 FORD Ranger
DEFINATELY check the wires on your brake switch..it's on the pedal shaft under the dash next to the inside of the fire wall...
Old 01-01-2003, 12:25 PM
Thanks for your help! That's what happened,I had a wire on the harness for my hook-up for my trailer had a naked place blew the fuse.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
