Hi again,
Thanks for the quick responses. Yes the t-case fluid is probably overdue for a change. I did notice that they're using automatic trans fluid in these now.... all my old 4X's and jeeps had regular gear case fluid in them. Yes, the truck does have a floor shifter... and this is definately a new sound considering I usually have the window down a little even in winter. What I think the problem is, actually is a bad pinion bearing. My brother called last night to inquire about the noise (he's a wrench on big const equip) and suggested when the dealership replaced the pinion seal in June that they didn't pre-load the bearing with the proper torque when they re-assembled the unit. Well it looks like it's off to the dealer.
Chris
