F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-28-2002, 05:13 PM
Account Suspended For Flagrant Cross-Posting
Vehicle: 1998 Ford F150
Where can I buy the Sonnax valves from?
I'm looking for the Sonnax By-pass clutch valve and the Sonnax Pressure regulator valve. Where can I find them?
Old 12-29-2002, 01:44 AM
WLF WLF is offline
Vehicle: 1997 Ford F150
This is from a post when I did the Sonnax valve replacement. I hope it helps.
Heres the information:
Spoke with Sonnax
Here are the part numbers they gave me for their products:
Pressure Regulator Valve - #76948-09
Pressure regulator boost valve (highly recommended by them to go with the PRV - #76948-02K
Bypass Clutch Control Valve- #76948-04k
Also they turned me on to ATC Transmission parts. Here in Baltimore they blew away Baumann for price.
If you want to find a dealer in your area you can call Sonnax at 1-800-843-2600. Their tech guys were very helpful. They also said to drill out the existing sleeve on the bypass valve with a 1/16 drill and strait out the other side. The instructions say in some applications. Sonnax says now it is on all applications.
Give Sonnax a call or check your local Yellow pages for the number.
Good luck and have fun with the install...
Black 1997 F-150 4x2 Supercab Flairside with HD tow package, Sunroof.
2002 Lightning headlights.
Steel Horse billet grill with Blade Runner (I just love chrome).
Prestiege air dam.
4.6L with Superchip, K&N Generation II modified to use with Supercharger, Accel Coil Pacs, Troyer fans, Troyer trans cooler, Cat back Exhaust with Flowmaster Super 40 2 1/2" in and Duel 2 1/2" out with 3 1/2 Stainless tips out the back.
S.E.C. Polished alloy wheels, Style 27 (17X8) with 265/70-17 Bridgestone Dueler A/T Revo’s tires. Hellwig 1 7/16 front and 1 1/8 rear bar. Eaton Limited slip, 4.10 Ford Racing gears, TrickFlow rear diff support girdle.
Pioneer head unit with Cerwin-Vega 5x7's all around and Rockford Fosgate Sub in custom box with 300 watt RMS amp "THUMP-THUMP".
http://www.f150online.com/galleries/....cfm?gnum=1496
Powerdyne Supercharger at 9lbs, 42LB injecters, 90MM MAF, Superchips 4 program chip.
JBA Jet coated headers
How fast am I you ask;
"Slower then John Force... Fast enough for me and exactly as fast as I can afford"
NOW 9 YEARS OLD AND STILL TURNING HEADS!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
