Tom, I tow a 6500# GVWR 5th wheel in the mountains of Colorado and use the engine braking technique you speak of. I have never seen the tranny temp go up when descending a grade in 2nd gear. If you apply the throttle your torque converter will unlock for 10-20 seconds then lock up. At that point the RPM's will go a little higher. When the TC is unlocked it generates more heat, which is your tranny's worst enemy.
I recommend installing a tranny temp gauge so you will always know if you are pushing (or pulling) it too hard.
I hope this helps.
PS I noticed you went to LT rated tires, wise choice.
'00 F-150 Super Cab Tow pkg. 5.4, 3.55LS, Superchip, Cervini's ram air hood, CIPA X-Mount extendable tow mirrors, Autoguage Mechanical Trans temp gauge in single pillar pod (kept my grab handle), Tekonsha Prodigy brake controller, Reese 15K Quik Slide, rear Hellwig anti-sway bar, BFG LT245/75R16 Long Trails....others
