12 Ecoboost 3:55 gears 8000 lbs ?
You can always combine a WD with air bags. Let me know if you have any questions!
https://www.airliftcompany.com/works...s-air-springs/
If you have air bags, you can add pressure to them to raise the rear end of the tow vehicle when tongue weight is applied so that the tow vehicle "looks" ok. But, virtually all the extra weight (10-15% of 8000#) is now being carried by the rear axle. That's 800-1200#! And, if you now make use of a WDH, it will be doing nothing (except adding more weight).
Unless you set up the WDH correctly, you are likely to exceed the weight limit on the rear axle of the F150. You can find that limit on the door sticker, and you should take your truck and trailer to a CAT scale to verify that you haven't overloaded your truck.
Personally, I think an 8000# trailer is too much for the suspension of an F150. You need a SuperDuty.
- Jack
