real towing capacity
Old 08-04-2012, 08:17 AM
ryanamy's Avatar
With a TT I'd try to stay a bit under since you will probly pull it a good distance. As someone else said, distance means a lot. I have no problem pulling the skiddy and a bale at roughly 16.7K a short distance. Truck handles it fine, but I wouldn't want to drag it 1/2 way across the state if I had a choice. Higher speeds and hills would really make me hate it. Old man has a 5th wheel camper that isn't far below his max towing and does it fine, could use a Roadmaster or bags for a little nicer ride but doesn't sit overloaded or anything. Has the same ratio as you do too. 3.73's would probly help a lot and would make it even loaded a good ways below his sticker. He's still looking around for an F250 just because the towing for the farm is far heavier at times than what that camper is.
Quick Reply: real towing capacity
