09-24-2010, 12:53 PM
Acceptable tranny temps while towing?
Hello again everyone. I have recently properly set up my 2010 SCREW 5.4 V8 with the WDH with sway control, ordered a tongue weight scale, a Scangauge and a prodigy 3 brake controller. Everything works well and I have tested everything out, weighed everything empty and full, etc with no problems. I am towing a 26 foot work and play with two motorcycles through the south from Mississippi to Virginia, so it is fairly flat with no mountain passes or anything to deal with.
My last question is this: On my Scangauge, when towing, what are the ranges for my transmission temp I should be looking for?
What options are any of you guys who suggested a Scangauge running on your display?
It is a new toy and just wanted to see what some of you guys have already figured out? Thanks a million for all the tips and advice. Also, the tongue weight scale is only about 130 dollars and worth the money as opposed to worrying if you loaded everything right in the trailer. I will post pics in a few days.
09-24-2010, 12:58 PM
2009 Ford F-150
Vehicle: 2009 Ford F150
CS & CTS for '09-'10, How about some updated stats???, post #21 starts a discussion (i.e., thread crap) on tranny temperatures.
WELCOME BACK MGD!
My fuel mileage: http://www.fuelly.com/driver/shotgun/f150
Quote:
Originally Posted by MGDfan
"The Spoon Department is now closed. Please proceed to the Self-Help Department, 3 doors down. Door is unlocked, but you will need to turn the **** and actually open the door yerself. Otherwise, be prepared to stand in the hallway unnoticed for a very long time."
09-24-2010, 07:07 PM
Bottom line? If it exceeds 210 for more than a couple of minutes, slow down and let it cool. If it hits 250, pull over and throw it in Park and wait till it's under 200.
2003 F-150 XL RCSB 2wd 4.2 M5OD 3.55 LS
09-25-2010, 06:30 AM
Garage is empty, add now
Vehicle: 2004 ford E-250
in my van with the optional cooler added in series- towing 5k lbs , ac on in the 90's,on the steepest grades in western pa,i have never gone over 175 in 2nd gear~4500-5000 rpms
2004 E Series Super Duty VANGINA
-SCT x-cal 2
-ASP Underdrive pullies & Goodyear Gatorback Belt
-Magnaflow 2 1/4" SS, x-piped,mandrel bent dual exhaust-#14335 mufflers
-Tru-Cool V-10 40,000 lb gvw transmission cooler #4379
2006 Honda CBR1000RR-157.2 rwhp,82.5 ft.lbs.tq
2011 Ktm 450 SXFs-+25,Vet A,+40 A
09-29-2010, 12:19 PM
08 F150 5.4 3.73. I tow a 4050lb TT and have a
Scangauge. I see normal towing temps around 150-170 depending on air temp. I see 200-207 climbing 6% grades for 5-10 miles. Usually the 200-207 isn't reached untill I reach the summit. Never gone over 207. Water temp will hit 203 on 6% climb also. Not much increase on water temp as it is allways around 198. Just driving through the CG looking for a space the trans temp will run up around 180-190.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
