F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Towing & Hauling
Thread Tools Display Modes
Old 10-23-2009, 08:29 AM
Vehicle: 2006 Ford F150
Cruise control and towing?
I have a 2006 5.4 screw 3.55 LS gears. I'll be pulling a trailer to Florida this Christmas. Trailer weight with cargo would be approx 2500 lb's. Will I be able to use cruise control?
Mark
Old 10-23-2009, 08:37 AM
Vehicle: 2009 Ford F150
As the owners manual states, do not use cruise while towing.
Old 10-23-2009, 09:53 AM
Vehicle: 2006 Ford F350
Quote:
Learn something new every day. I never knew you were not supposed to use cruise control while towing.
Dave
2006 F350 CC FX4 6.0 PSD
Optima Red tops, Lorado bed cover, HD head lights, Cobra 29LTD, Dual K40 antennas, Recon 60" Fire and Ice bar, Recon smoked clearance lights, Recon smoked mirror lights, Whelen Hide Away Strobes, PTM handles and mirrors.
Quote:
Originally Posted by awalkinrain View Post
Too much work ruins a good slacker. :lol:
Old 10-23-2009, 11:16 AM
Probably biggest reason is lag in case of an emergency. That and also more downshifting when the cruise is trying to keep a steady speed.
Old 10-23-2009, 12:20 PM
Good to know and thanks for the replies!!
Mark
Old 10-23-2009, 12:46 PM
Vehicle: 1997 Ford F150
With that load, you can probably get away with it on totally flat hwy runs.... But, as the others have stated, it's not something you would want to do on a regular basis...
The CC will want to get you back to your set speed as soon as it can, so if you start to slow down on a slight grade, it'll start giving it gas to pick up speed.. Since you have something tied to your butt that is making this harder to do, it presses the gas more... Soon, it'll just 'floor it' to get back to it's set speed and that's not what you really need it to do..
You would probably do best not using it at all, but your road conditions will be your major factor.. Flat and no head wind and you can get away with it for the most part...
You will probably be able to run in OD with that load, so don't fret too much on that part.. Lock out OD if it starts shifting in and out of OD as that's harder on it then just running the higher RPMs for long periods of time.
MItch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 10-23-2009, 06:17 PM
glc glc is online now
Vehicle: 2003 Ford F150
2500# is nothing, you should be able to use it everywhere except in the mountains. I use mine all the time when I'm towing with my manual tranny in 5th.
I balance off the safety issue with the advantage of speed control and it being less tiring to drive.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-24-2009, 10:21 AM
Vehicle: 2003 ford f 150
Send a message via AIM to MonteCarlo31
I personally use cruise if I have the space on the highway all the time. I've run truck harder the 99% of the owners out there and have never lost a engine or trans. My 03 F-150 I ran 35s w/ a correct speedo and 3.55s and used cruise all the time, never once had a issue even pulling my XJ on a 18' 3200 lb trailer. My 06 silverado the same way without fail, even the new expedition without issue.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
