Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Towing & Hauling
Thread Tools Display Modes
Old 08-28-2008, 04:25 PM
Vehicle: 2006 Ford F-150
factory hitch question
Are you guys towing with the factory hitch or are yall replacing it with a different one? The reason I ask, is that most hitches are spread out along the frame and this factory one just bolts to the end of the frame. From an engineering standpoint I would think the ones that bolt on with 6 bolts and spread the weight down almost 3' of the frame would hold better and be safer. I'm only towing a 24' boat that weights about 6k going down the road and my flatbed will hold 7k and is close with my tractor and brushhog on it. I just moved down from a F-350 to this 06 F-150 and I want to make sure the hitch will hold up.
Also, what can yall tell me about the transmission cooler that I might need to know. Do I need to install an auxillary or will the factory one keep up?
Old 08-28-2008, 05:53 PM
Vehicle: 2008 Ford F-150
I tow the same size boat with mine, no problems yet. I have only had the truck for 2 months though.
A few years ago I stupidly pulled a farm tractor with calcium filled tires on a car hauler behind a 99 ranger with only the factory hitch and never had a problem with the hitch, the only problem i had was that the front tires did not want to stay on the ground......
Old 08-28-2008, 06:43 PM
I was told by the Ford salesman that the truck would tow 9k. But when I got home and looked at the bumper is says 9k if weight distribution. Well I don't have that on my flat bed or boat. and 5k without. My boat alone will be pushing the 5k much less my flatbed.
Old 08-28-2008, 07:59 PM
Vehicle: 2001 FORD F150 4x4
Quote:
Then you better move back up
Old 08-28-2008, 08:34 PM
Vehicle: 2007 Ford F150
I am assuming the boat is 6K # including the trailer.
You referred to the flatbed as carrying 7K #. What is the GROSS WEIGHT of the trailer and load combined?
I am thinking the F150 is rated to tow a MAX of 8K # if properly equipped, This means 5.4 engine with Auto Trans, Tow Pkg. and 2WD. This is also a regular cab. As you go up through the cab sizes, the tow rating goes down.
My Screw is rated for 6.4K because it only has the 4.6 and the heavier cab.
I think you should at least go to a WD hitch for your loads.
I do not have the factory tow pkg. I added a U-Haul class 3 receiver hitch to mine. It is rated for 6K # and is only mounted with 4 bolts at the end of the frame. If using a WD hitch, it is rated for 10k #. I would trust the load rating from U-Haul. They are liable if it fails. This should keep them honest.
The tranny cooler on my truck looks pretty good. I think the other posters advise that the tow pkg. comes with a bigger cooler. Yours might be better than mine. However, TX and CA (where I live) are both very hot places and you are pulling a heavy load for a 1/2 ton. Might be good to step up to protect the tranny.
Good luck.
2007 F150 XLT SuperCrew
2WD/4.6L/Auto/3.55
Gold w/Beige Interior
Tinted Glass All Around
Pendaliner Bedliner
Michelin Rubber
Previous Ride was a 1998 F150 XLT SuperCab
Red with Silver Trim
On my 2nd F150 and loving it!
Old 08-28-2008, 09:12 PM
Vehicle: 1999 FORD F150
youll be fine depending on what motor. Don't know what kind of boat you have, but these are pretty damn heavy. Note, these were all pre AAL on the factory tow package. Only upgrade is a brake controller.
21.5
19.5
^dirtyd88 is the man^
1999 F150 4x4 5.4, T3 front end replacement (the cow killer), T3 straight rear bumper 8" drop, Skyjacker AAL, T-bar maxed, Toyo Open Country, AT 285/70/17, Flowmaster true dual exhaust, Kobalt skinny truck box, Icom IC-V8000, Cobra CB radio, tint, Yeah that about covers it...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
