Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Towing & Hauling
Thread Tools Display Modes
Old 07-21-2008, 09:02 PM
Vehicle: 2001 Ford F150
Wdh
I am looking for a weight distributing hitch for my 24 ft car hauler.
It is a V front trailer. The V is about 2 ft. But this makes the tongue only about 35 inches long. Is this long enough for a WDH?
Steve
Old 07-21-2008, 11:46 PM
Vehicle: 2001 FORD F150 4x4
here is a link
http://www.reese-hitches.com/product...tribution_kits
Old 07-22-2008, 01:16 PM
Vehicle: 2005 Ford F150
I have the Reese Straight-Line and really like it.
Quote:
Originally Posted by bigdad8214 View Post
The reason I was asking was I already had a Equalizer on order. I just hope it fits.
Old 07-22-2008, 04:19 PM
Vehicle: 2007 Ford F150
Quote:
If I remember correctly the brackets on the equalizer are mounted at ~26". You will be fine there. Only problem may be when you turn. The end of the bar may come into contact with the side. I would mount the hitch in any position (not important) and attach the bars to the hitch. Don't worry about attaching the bracket to the trailer. Then turn slowly or with someone watching to see what happens. The bars will be about parrallel to the frame of the trailer (in real mounted position). If it looks like it will be ok then setup everything the right way and mount the brackets on the trailer. Reason I say don't mount the brackets to the trailer initially is you will probably scuff them up a bit in mounting and turning then may not be able to return if its not going to work. Hope that makes sense.
You could also call Equalizer and ask them..
Old 07-22-2008, 05:34 PM
Quote:
Thanks. Thats a good idea.
Old 09-13-2008, 06:50 PM
Well last week I finally got around to having the Equalizer hitch and Atwood power jack installed. I cannot believe what a difference it made. The one thing I do not like is all the different pieces you have to pin together when hitching up. Other than that it's great.
Changed the trailer so the lights would work even when it is not hooked up and the jack works also. I had them put two large deep cycle batteries. Quite a bit of weight, but I believe it was worth it.
Thanks for the help on this and other things.
Steve
Old 09-14-2008, 11:47 AM
Vehicle: 2006 Ford F150
Another happy Equal-i-zer WDH customer. Our TT is 6,000 loaded and we use the 1,000/10,000 unit. Works like a champ.
You mentioned a power jack. While not a necessity with the Equal-i-zer, it sure makes the job easier. Especially when you have been driving all day and when you get to your destination its hot out... ah yes, power jack.
2006 XLT
4x4
5.4 3v
3.73 LS
285 60 18 Toyo Open Country AT
AMP Sixer wheels
Arma Coating bed liner
Fender flares
AS 2 inch level kit
Magnaflow muffler/exhaust
AFE intake
Edge Evolution programmer
Tows a Jayco Jay Feather 26S
GALLERY:
http://www.f150online.com/galleries/....cfm?gnum=7836
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
