Just to be clear....the 7700 package is the heavy duty payload package, raising the GVWR from about 6500 pounds to 7700 pounds. It is indepenent of the towing package.
Here are the contents:
7700 Lb. Payload Group A (V-8)Includes:
GVWR7700-lbs.
Powertrain5.4L engine with 4-speed automatic overdrive transmission and 3.73 axle ratio (when
snowplowing, operate automatic transmission in overdrive)
GAWR/torsion bars, front4150-lbs.
Upgraded radiator (1.42 core thickness)
72 amp-hr-650 CCA battery
Auxiliary automatic transmission oil cooler (14-plate)
LT245/75Rx16D OWL all-terrain tires with BSW spare
16″ x 7″ J argent styled steel wheels (7-hole disc) (chrome styled steel with XLT and Lariat)
Other heavy duty componentsframe (4.00 cu. in. section modulus), shock absorbers (1.38″
diameter), jack (2-ton), rear axle (5300-lbs. capacity), rear springs/GAWR (4800-lbs.)
All F-150's since at least 1997 have at least the 4-prong trailer conenctor. The Towing package got the 7-pin wiring.
With the Hidden Hitch recevier and 4-prong connector, I'd say ypur truck does not have the OEM towing package.
Are you tring to add a brake controller?
