02-17-2006, 05:31 PM
Tow Package
Hello All: I just purchased a 2003 F-150 4.6, 4r70w, 355 LS Extended cab XLT. How do I tell if I have the tow package??
02-17-2006, 05:56 PM
Garage is empty, add now
Vehicle: 2012 Ford F150
Transmission oil cooler. (for auto trans). 7 pin connector (although these are easily added later).
02-17-2006, 08:33 PM
factory reciever hitch
fuse block pre-wired for trailer brakes and relays
02-20-2006, 07:18 PM
Vehicle: 2000 Ford F-150
Trailer Towing package includes a heavy-duty alternator, HD battery, super-cooling package, auxiliary trans cooler, factory hitch, factory 7-pin connector on the bumper.
-Joe
'00 F-150, X-cab, 4x4, Lariat, 5.4L Off-road, Trailer Tow, Holandia Sunroof($1000)Mucho mods
98 Explorer bone-stock (Lemon Law Case in Progress)
Photo Gallery Here
I'm not smart, just a resourceful idiot with some spare time.
02-20-2006, 08:24 PM
Look in front of your radiator. If there is a cooling device on the passenger side that's the aux trans cooler. That's a good sign you have the tow package along with all the other stuff listed.
02-20-2006, 08:34 PM
I could be wrong, but didn't the aux trans cooler come as a part of the super-cooling package? (which was, of course, a part of the trailer towing package) If so, an aux. trans cooler is not necessarily an indicator of the TT package.... it's all a little fuzzy these days.
-Joe
Photo Gallery Here
03-01-2006, 09:15 PM
Quote:
-Joe
Another package that you may have is the Heavy duty payload package which is identical to the tow package minus the reciever and 7 way receptical. Even though its not the tow package it does still have all the fuses and relays for brake controller. I
03-02-2006, 07:15 PM
Class III Trailer Tow Group (535)
-7-Pin trailer wiring harness
-Class III frame mounted hitch receiver
-Heavy Duty Electrical/Cooling Group (531)
-Heavy duty gas shock absorbers
-Heavy duty 72-amp hr battery
-Super engine cooling (radiator upgrade)
-Auxiliary transmission oil cooler (w/44E auto trans only)
-Upgraded auxiliary transmission oil cooler (5.4L engines w/44U auto trans)
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
