Quote:
Originally Posted by jon_herr
This fixed it for me - I haven't had one single time where sync was un-usable since this TSB was applied. Good luck!
TSB #11-10-22 for Sync reliability problems after vehicle start if USB devices are connected.
The TSB states that the Audio Control Module (ACM) must be reprogrammed to change power on sequencing if the customer states a concern with sync operation at startup.
The symptoms are - the sync system was not usable about 1 out of 5 times - requiring a shutdown of the vehicle and opening of the door until the Sync module (APIM) was de-powered and then powered on again... when I say not usable I mean that the voice button, aux buttons result in no voice prompt and the USB port is un-powered.
This is the exact problem I am having and it looks like that TSB might be right on the Money..... I'm copying and pasting this info right to the dealer.
Here’s the text of the TSB:
TSB 11-10-22 SYNC LOCKUP DURING VEHICLE CRANKING / STARTING - SINGLE CD OR SIX DISC CD - BUILT ON OR BEFORE 7/29/2011
Publication Date: October 20, 2011
FORD: 2011 F-150
The article supersedes TSB 11-9-7 to update the Action statement.
ISSUE:
Some 2011 F-150 vehicles equipped with SYNC and either a single disc or six disc cd player audio control unit and built on or before 7/29/2011 may exhibit a lockup condition of the accessory protocol interface module (APIM) when the vehicle is started. This concern may be more evident with a USB device connected and/or with the door open.
ACTION:
Reprogram the audio control module (ACM) to the latest calibration using IDS release 75.04 and higher. This new calibration is not included in the VCM 2011.9 DVD.DVD. Calibration files may also be obtained at
www.motorcraft.com.
NOTE: NAVIGATION EQUIPPED VEHICLES ARE NOT AFFECTED BY THIS CONCERN. PROCEED WITH NORMAL WSM DIAGNOSIS FOR NAVIGATION EQUIPPED UNITS.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
111022A 2011 F-150: Reprogram The ACM (Do Not Use With Any Other Labor Operations) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
18K810 04
