i have a droid x2 and it works great in my truck. connects fine and texting works as well with the sync
I have the droid X2 as well and i just got my truck last night.. I have already had three or four calls and they all worked fine...but i also recieved a few "new email" notices on my phone, but the truck gave no reaction at all.
the signal i get from my phone when texts arrive as well as when i get email noctices are the same,...... should i be recieving something through the synch system when i get the email notices?
I get the notice of the text arrival and it shuts the radio down, but i dont know if I need to DO anything to read th message, like hit OK... the one time I tried so fat i think I hesistated too much...
no problemI guess i got time to figure it out...
I had blue tooth installed in my vette whenh i put a kick assss stereo in it...and they wired a mic to the rar view and it interupted the music the same way when a call came in, but for some reason i didnt like it... i cant remember the motions i need to make to accept the call.....but in the end i disconnected it..
but this sync seems way more seemless....so far anyway... I like it.
matter of fact i love everythign about my 3 days so far with this truck ha ha ha
I have Verizon, Samsung Galaxy S 3G (Android), and nothing but issues. Phone pairs and connects, halfway through a conversation, phone automatically goes to "privacy" mode, or phone just disconnects. However, I assume it could be something wrong with the actual Sync module, so when it goes in for an oil change, I will have them check it. Any tips?
They will tell you that it is your phone and the only thing they will do is reset the system. I wouldn't waste the time on trying to get them to do anything.
I am using an LG Revolution from Verizon running on the android system and no issues yet. I have only had my new truck about a week, and I am still trying to figure it all out.
1998 F150 Supercab - gone but not forgotten
1993 Mustang Cobra
2007 F150 Supercrew - Traded for 2012
2012 F150 XLT Supercrew 4X4
My 93 Cobra Website: Click here!
On any Android based cell phone you have to "pair" the phone differently.
If you have already paired your phone, then consider doing a "Clean pairing." This means going to the Phone Menu, select System Settings, Bluetooth Devices, Delete Device. Select your phone, then push the OK button on steering wheel or dash to delete it. Then go to the phone, Settings, Bluetooth Settings, Connected Devices, then "delete" the phone. As an added measure, turn your truck off, raise the hood, then loosen and pull the black battery cable off the post for about a minute. Then replace it and retighten it. Close your hood and return to the truck. Turn it on. Let it run for about 5 minutes. Then turn the truck off, and open the door to make sure everything is powered down. Then restart the truck. Go to the Phone Menu, System Settings, Bluetooth Devices, Add Bluetooth Device, then push OK to begin pairing and the system will come back with a 6-digit PIN. For those of you with the LED screen on your center console, turn the tuning knob until it says Special PIN, hit OK, and it usually comes up with "0000" Then go to your phone, to the Settings, Bluetooth Settings, Add Device, when it recognizes the truck as "Sync" then tap the phone's screen and if it comes back with the keypad, enter the "0000" Then push Pair on the phone. (For those with the Touch Screen NAV system, you have to use the 6-digit PIN).
Be sure to watch, some Droids come back with a sub-menu that lets you keep the Bluetooth "Always On" -- tell it OK. The Sync system will then ask if you want to make this the Primary Phone, push OK on the steering wheel or console. Tell it OK on the 911 Assist. When it asks to Download Phonebook, now you can push OK, and OK again, and it will download.
The 6-digit PIN sometimes gets the phone confused so the Phonebook does not download completely, or at all. Using the 4-digit PIN corrects that and it seems to hold the Bluetooth signals better so it doesn't drop call or shift back into Privacy Mode.
Another thing to keep in mind is that, if you have registered on syncmyride.com, then you need to check back to see if there is a software upgrade. Switching to Privacy Mode and having the microphone not "hear you" is usually due to old software that needs to be updated. Also, about once a week, be sure to power down your phone. Then restart it. Also, check to see if the firmware on your phone is current. See my website fordtechlane.com for more info
could one tell me why in the world i would want to do this when my andorid.. Incrediable works fine
Yes, any Android-based system may work using the standard pairing process and the 6-digit PIN, but at some point there may be a need to re "pair" the phone -- and this is one procedure that works.
I have a T-mobile samsung galaxy s 4g. Sync will not connect all the time, the phone book will only download 2 out of a lot on contacts. Sync's never told me I had a text message, so I will have to check on that.
I'm also having a problem with the driver's side front speaker having low volume. The dealer says this is a sync problem too and a re-flash will fix it all? We will see!!
Donuteater.... when you "paired" your phone did you use the 4-digit PIN instead of the default 6-digist PIN? I've found that if you do a "clean repair" and use the "Special PIN" when you attempt to pair a Samsung Galaxy S a gain, it will usually download the entire phone book. I don't think the Galaxy S is supported for text messaging... See my blog at fordtechlane.com for handling more issues with the phone book...
