Which tires can I fit??
I'm hoping soon I can add 6" to my 01 F-150 and have a total of 9". What size tires can I fit? I'm seriously considering the 38/15.50/16 or the 38/15.50/16.5 Parnelli Dirt Grips. Will these fit w/ 9"'s of lift? Also, since my truck came with the larger lower valence for the foglights, would I be better off changing to the 97-99 chrome bumper with the foglight openings? Wouldn't the 97-99 bumper give me better clearance? I'm open to anyones suggestions! Any help ya'll can give me will be greatly appreciated!!
Thanks,
Tommy
Thanks,
Tommy
So, your saying that you already have a 3in body lift???? With a 6in suspension and a 3in body you should be able to run the tires you are wanting. I havent done much comparing on the front valence on the new ones. But, if they are bigger than yea, i am guessing an older style bumper probably will give you more clearance. You dont mention if your truck is 4 wheel drive or 2 wheel drive. If it is 2 wheel drive than i dont think you will be able to fit those size tires. It seems that lifts for 4wheel drive end up being higher than the ones for 2 wheel drives.
https://www.f150online.com/galleries....cfm?gnum=1680
check out my truck when it was on 38''s now my truck sits on 37''s
