The old squeaky pitman
Hi there ..... as mentioned repeatedly on here I hae the dreaded squeaking steering problem. I know many people in here have greased and fixed this problem themselves, but has anyone got any info on ford fixing it? cost parts etc? Isn't filling the boot just a band aid cure? Any info would be of help THX
I have a 1997 F-150. I too have this squeaky pitman arm, because when I turn my steering wheel it squeaks and drives me crazy. When I turn the wheel left or right to pull into a public lot I get so embarased, because everyone looks. I e-mailed Ford to let them know about my problem or to see if there was any recalls on this matter and they called me back (shocking) they said to take it in to my local dealer to have it evaluated, of course I will have to pay for the eval. and from that they will determine what it is. All of us F-150 owners with this problem should e-mail or call Ford at 1-800-392-3673 to let them know about this, maybe it's just a bad design and we shouldn't have to pay a cent for this repair.
squeeking fords
My 1999 Ford F150 just started making a noise in the pass front side. It sounds like it's coming from the steering arm. Because I bouhgt my truck 3yrs and 3months ago (32,000 miles), Ford dealer said sorry 'bout your luck. I am going to try to grease the steering arm and ball joints by using a needle insert. Any suggestion or ideas if this will work? I'm so happy with Ford right now!!!!!!
$80
I dont think a Ford tech can scratch there ***** for $80. They damn sure arent going to replace a pitman arm for it.
I was one of the first to post about the needle gun lube trick and haven't heard a peep from mine in the past couple years. I check the front end for an play every couple months and there is still no play in that joint. As far as a band aid, I don't think so, There should be a zerk there from the plant.
Poke it, grease it, seal it!
The noise is embarrasing for all Ford truck owners.
Well Ford Corp. called my local Ford dealership and set up a appointment to have this fixed, my cost a $50 deductable. My truck has 65,000 miles on it, so it was way out of my extended warranty. I guess "the squeaky wheel does get oiled" after all. Call or e-mail Ford Corp. like I did so they know about this failed part and so we don't just put a Band-aid on it.
Originally posted by tcabrera
Well my local dealer fixed this sqeaky pitman arm and it cost me $16.25, not $50 like they said the deductable would cost. They put a new pitman arm and fitting, not a band aid fix . NO MORE SQUEAK FINALY. Thank you Ford Corp.
