'97 Expy with 4-Corner Airbag Susp... questions...
Old 10-21-2002, 04:57 PM
Bushwood's Avatar
I've had this truck for a couple months and put about 10k on it. Since I've owned it, the front-end has squeaked and creaked when I turn the wheel - stopped, noise from outside under vehicle... sounds like bad bushings. There is also a clunking coming from same area.
So, the questions - is there a replacement bushing kit (Energy, etc.) that you guys would suggest?
What are my options regarding shock replacement - with 4-corner airbags? I've found none.
Thanks!
Old 11-04-2002, 10:57 PM
SexpeditionSprt's Avatar
I put the poly Energy kit on my mustang and it squeked a little bit, but I did EVERY bushing on the car at the same time, and noticed a huge difference, however you need to use a marine grease on the bushings, all over then, or grease them often at least becasue they will squeak.
Quick Reply: '97 Expy with 4-Corner Airbag Susp... questions...
