Am I Insane......
Am I Insane......
....for obsessing over my steering? Maybe...but you are insane for typing this answer to your own question....ha!
In my continued quest for quicker steering, I asked someone who has a very stock, 99 F-150, 4.6, single cab style side truck with only 21,000 miles!!!!, to let me drive it tonight. I have a 99, F-150, 4.6, supercab, flareside with lowering kit, performance tires, hellwigg sway bars and a hard, flushmount bed cover with 67,000 miles .
I noticed a big difference! This other 99 F-150 had "tighter steering, with far less "play" in the steering than mine ever has since I bought it used with 43,000 miles, 11 months ago!?!?!?
I am not talking about tire or suspension performance. Just the play in the steering was far less in the other truck.
My question is, If one truck has tighter-less play steering than another truck of the same general type and year with the only major difference being that the better steering truck has far less miles on it, what could be worn on my 67,000 miles truck that could be causing the play in my steering????? Idler arm, pitman arm, end links or front wheel bearings?
Is there a front end component that affects steering play and wears out faster than the rest?
spaceman12321,
Nice bike!
Thanks for your comments. I thought about that. On some of my older cars, I would adjust the slack in the gear box. It would make my steering wheel tighter to turn, but the "slack" or play in the steering and movement of the wheels in relation to the steering wheel only more pronounced (worse).
I was hoping someone knew which one of the steering components that tends to wear out faster and affects steering sensitivity moreso than the rest of the components?
Thanks again.
Nice bike!
Thanks again.
I would guess that your pitman arm and idler arm would wear out the fastest. I know that both of mine need to be replaced as it is. When you have someone turn the steering wheel for you, look at the pitman arm and see if there is any play right there. Then check your idler arm. When you are looking at the pitman arm look and see if the pitman arm moves with the rest of the parts. If there is any play there then it probably wont. Another thing you can do is lift the front end of the truck up and wiggle your tires side to side, and that should point out any play. Try that and let me know if you find any thing.
It could be the pitman but more so the idler arm. The pitman doesn't really consist of that much and doesn't seem to wear that quick. I can tell you what part you might wanna check out and replace.
It's the lower steering shaft the runs fro mthe gearbox through the firewall and connects with a u-joint type fitting at the steering wheel. I bought my truck ( a 97 4x4) used with 86K and it felt great compared to dads 94 with less than 65K. That's until my borther in his 98 4x4 with less than 50K came for a visit. His was much tighter, more responsive and less bumpy feeling.
I had my shaft replace at a dealer for like $65 parts (regularly 85)and $65 labor. That's cheaper than most as all the techs there drive F150's and Rangers and I talked the service manager down by showing him the price off of fordpartsonline. It and having my tires balanced solved almost all play, steering is tight again, doesn't jar when going over bumps, etc. The reason I said almost is I might also have a bad cv or axle bearing cuasing what play and motion is left. I do know of at least one guy on here that had to have his replaced under warranty (so 36K). So that means they can/do wear in early stages of the trucks life.
offroadmaniac and KY FordFreak,
Thanks very much. That is the kind of detailed info that really helps the mechanically "UNinclined" like me! ha!
Now I can go do some checking and know what I am checking for! ha!
I really appreciate the effort.
I have noticed over bumps or "washboards" I can hear and feel a "rattle" in my steering. Does that mean too much play somewhere in the steering?
Hey not a problem, I know how it is. I spend my days trying to help people with car problems so whats a few hours on the computer every night. I just wish I could find an electrical whiz to help with this stupid fog light mod.
Raoul is a funny funny man.
You know that statement could be reversed a little.
" You shouldn't think about everything you believe in"
Whenever I do that I leave more confused than when I started.
I like the one "It's fine when you talk to yourself, when you start anwsering yourself it's time to be admitted"
Location: Houston, by way of every major city in America.
on
And don't forget you drove a truck with a shorter wheelbase, that would make it "seem" like it had quicker steering?? I recently felt like I had slack and sloppiness in my steering, and it was worn out shocks and unbalanced (and unrotated) tires. the truck was all over the road following ruts, and washboards sent it reeling. What could it hurt to drive it into a shop and just have it looked at. I did, and it saved me several hundred bucks in rebuild parts and labor.,,,,98
KYFord Freak,
Fog Light Mod? I wish I could help you. I just figured out which parts to get minus the wiring. It is going to cost me $160 for the brackets and lights for the L bumper fog lights (I really want driving lights however) So, more than likely not, I am going to cut out some black plastic and fill in the holes for now.....ha! I know when I did a search I found some posts on the wiring. If I can find them again, I will post them for you.
98',
I have taken it to two shops. when I tell them what I think my problem is, they look at me like I am nutts and say....."its a truck and a Ford" Infact, one of the shops is the one that did my wheel alignment after I lowered it and while he was aligning it, I asked him to check the front end for worn parts and play. He said he found none. When I went back to him, I asked if there was some "highperformance" pitman or idler arm, end links or some gizmo that would improve steering control. He said, I could get after market parts that have grease inserts, but no increase steering control.
The other shop is suppose to be one of the best in my state for truck suspension and they said there was no need to even inspect it? They knew exactly what I wanted and said it has not been developed yet. Although, this expert truck shop did suggest that I get a Lightning steering gear box. When I said that the Lightning uses the same 14 to 1 constant ratio steering, they said that, "well then, I guess your out of luck"
I have gotten the impression over the past 10 months, that if a person has mainly driven a truck, they are use to having some play in the steering and even prefer it. I have mainly driven sports cars and motorcycles. I am not use to it and can not get use to it.
The new 2003 Dodge HD 4 wheel drive has the fastest ratio steering of any truck right now with a 13 to 1 constant ratio. They use the same Visteon gears as our F-150s. I am trying to see if the gears will work in my steering gear box.
As well as you would think that there would be aftermarket components like pitman/idler arms, end links, etc. that would increase steering sensitivity??????
98',
