Newbie: Want to level truck stance??
Old 09-12-2002, 02:25 AM
alleyway28's Avatar
I just bought a 2002 Supercrew, and I'm not going to mess with the suspension for right now; however I would like to lower the rear a tad to be level with the front. What would be the easiest way to do this??
Thanks,
Marc
Old 09-12-2002, 03:37 AM
AjRagno's Avatar
Re: Newbie: Want to level truck stance??
Thanks,
Marc
Easiest??? Without messing with the suspension???
Let the air out of the rear tires......
Old 09-12-2002, 01:59 PM
LakeSands's Avatar
Is your truck 2x or 4x. If it is 2x you probably don't have a cheap solution. If 4x, then crank up the torsion bars a little and have an alignment done. Its free except for the alignment.
Old 09-12-2002, 02:02 PM
PhillipSVT's Avatar
2x4's have a really really cheap option. Less than $50 will get you a new rear shackle that will lower the rear 2" and pretty much make the truck level. Any Pep-Boys, Auto Zone, Orylies (sp?) or any other vehicle shop should have them. Its still a faily easy install, no allignment needed.
Old 09-12-2002, 04:16 PM
alleyway28's Avatar
Thanks for the tip.... Phillip.... I was thinking about that, but I didn't know if there was a special kit or not..
"AjRagno" For some strange reason I like keeping air in my tires...
Thanks for being so unhelpful...
Old 09-12-2002, 04:26 PM
PhillipSVT's Avatar
I think the only thing you would have to look for is like Ford-97+ 2" drop shakle. They probley make them for all fords, chevy's, dodges, but should be failry universal if it say's Ford F-150, 97 and up.
Old 09-12-2002, 05:19 PM
AjRagno's Avatar
I'm the only one that offered advise within the guidelines you specified and you get upset??? Very peculiar
If you use drop shackles or crank the torsion bars, you're messing with the suspension.
I don't think I can answer your questions anymore if you're not going to be serious
Old 10-09-2002, 07:31 AM
flawcee's Avatar
don't lower the back raise the front. 2 wheel drive get a lift spndle if it is a 4x4 just crank the torsion bars all the way up.
Quick Reply: Newbie: Want to level truck stance??
