"check Susp"
"check Susp"
Yesteday, I stopped at a Goodyear store nearby - they are the only ones in the area with a tire tester... the thing that simulates driving and will test for a bad tire, bad wheel, bad balance...
Anyway, the store manager said the noise I was getting in the front wasn't a single bad tire - I suspected this, hence the reason for going to that store. He said all of my tires are badly cupped. They are Goodyear Wrangler RTS - OE parts, second set, about 15k on them. He said he'd put a new set on for 50% of the cost... actually seemed fair.
But... back to the "CHECK SUSP"... when I drove out of there the "CHECK SUSP" light was on - it's still on. I've got a '97 with the Load Leveling Suspension - all 4 corners.
The truck is riding like a brick - seems like the airbags must be pumped to their max??? I'm getting a clunk in the drivers front corner....
I'm confused - How can putting the truck on a lift screw-up my suspension this badly?
What should I do?
Thanks.
What should I do?
Thanks.
