Truck is leaning...
Truck is leaning...
My truck is leaning to the left (from behind) and I have been hearing some odd noises coming from around the front left wheel area (soft metallic clanking)... Also... when I go around turns at normal speeds the front left wheel is squealing like im taking the turn at formula one speeds. Any ideas? I have been under the truck a few times and I am unable to pinpoint the problem. Other than this the truck drives fine. I noticed the problem 2 weeks ago...
leaning problem- have you made sure its not just leaning when your tank is full...sounds stupid, but a full 25gal gas tank on one side of the truck will make it lean a little...
if its leaning more than a little...
saggy leaf springs most likely...mine leaned and i had to replace parts of my rearend (leaf springs included)...it helped (but it still leans a little :o )
metallic-y sound-
metallic-y sound-
If the entire side (front and back) is leaning, then it could be a torsion bar related problem...
The torsion bars change the degree at which the wheel sits in it's flexing parameters...in other words, it will lift or lower the truck...there are two bolts and these can be adjusted with some WD-40 and a socket wrench. Follow the bars under the truck running from the front suspension back into a bar perpindicular the length of the truck. Where these bars end, you will notice a bolt inside the bar that you can turn which will in turn, rotate each bar. Tightening the bolt will lift the truck, loosening will lower it...if you turn the bolt too much, then you might find your alignment will go bad because you have put the tire at more of an angle to the ground as you lifted and lowered it...this is not a serious thing but the truck will require an alignment if you leave it at this setting...
The torsion bar solution is always a free fix if you dont figure out what is wrong...i noticed mine always leaned...i hardly ever notice it anymore thanks to the torsion bars...and i think it has more to do with the gas tank and ground level now when and if it does...
Just something to check or a free solution
