stering stabilizer
Location: Houston, by way of every major city in America.
on
I just had one recommended to me the other day, by a suspension guy here in OK. He suggested it was a good idea for anyone who drove faster than normal speeds(80 plus) Like me I guess it's on the list now. Would it matter if a truck is lowered or not? That's coming up in the future of my truck.,,,,98
I know Rancho and Fab-Tech makes them for late model trucks also. I was thinking about getting one and I checked at about 3 different places (one of them being 4wheel parts) and they all said you would most likely never know it was there unless you had 1. 35" tires or bigger or 2. doing some "serious" off roading like high speed baha stuff through the desert. I decided to pass due to a lack of 1 and 2. Buy yea, they do look cool. I'm still thinking about it cause it sure ain't going to hurt anything.
IMO, while they are mostly needed with larger tires ( again IMO over 33) I do run on my truck with the 31.8 inch tall tire. I noticed all around better steering wheel fell at all speeds. It seems to really help when hitting a bump while going through a turn. Right now I got a shimmy from someother component so the effects are low. I plan to pull it off and drive around a day or two to check things out and remember how it feels without one. I usally do not do much over 80-85 for too long as my truck is not setup for speed and I'm sure the BFG AT's are not to highly rated on the speed chart.
I did have one guy tell me, that if your truck needs a stabilzer than you have bad suspension/steering components somewhere. I completely disagree and consider this BS.
Checkout Skyjacker for steering stabilizers.
I have 3 on my truck....and man do i need them.I had 1 of the 3 go bad and i felt the difference immediately.
It might be a good idea too,in case you get a blowout...it will somewhat control the steering and the vehicle.
Hope this helps.
Jerry D
Hope this helps.
Jerry D
