Leveling out the rear/ tire&wheel change
I own a 01' reg. cab f-150. And I am interested in leveling out the rear to match the height of the front end, and installing a set of 20" wheels and tires. Would this look good? I mean without drastically dropping the truck? If so, where could I find a rear leveling kit? Any help is appreciated. Thanks.
To just level out the rear to match the front, you simply need rear 2 inch lowering shackles. They are made by several companies such as DJM Suspensions, Suspension Techniques, Ground Force, Belltech, just to name some. They very easy to install and run about $50 for the pair. They can be purchased from any on-line truck performance websites. Your truck will look great with 20's, I have a supercrew that I dropped 1inch in front and 3inches in back with 285/50R20 tires.
