Fabtech 3.5 Spindle Lift
Ive got a Fabtech 3.5" Spindle lift for my 2000 f150 2wd. My question to anyone who has done suspension work like this is, would it be eiser to just put some preload on the lower control arms and then remove the spindle. Or Use a spring compressor and then take off the spindle. I have a lift I am using and I figure that it would be eiser to use spring compressor so i can have the truck up high. Also any one have experience with the cam alignment bolts. Do you really have to use the ones they give you? There shotty instructions mention nothing about them!! Thanks
Glenn
Glenn
