Coil Spring Spacers
Coil Spring Spacers
I'm wanting to get to lift really cheap. How much lift can I get with just Coil Spring Spacers? How bad will it affect the front wheels towing in or out and would that greatly affect tire wear? Where is the best place to get them the cheapest? I would be thankful for any help anyone can give.
actually, they are the same as the factory ride. the thing u need to watch is the size od the spacer, because if u go beyond the height of the shock u will have to replace it to.
i was going to add them to mine, but when i found out the labor to install the spacer was the same amount to install new coils. so i decided to upgrade my coils completely, because it only around 80 dollars more for new fabtech coils.
and honestly i think it rides alot better!
hope this helps,
mc
hope this helps,
mc
