frame exposed after body lift, temp fix?
I just reinstalled my front tow hooks, after a 3" body lift. I may have a temporary solution to the frame that peeks out where the tow hooks used to be. I cannot be for sure how the end result will be, I am waiting for some glue to dry. however it looks a hell of alot better than the rusty frame. Please respond if interested. I will keep you all informed. chris
fix for lift
well it has been one day so far, and the covers that I used are still holding. First this method will only work, if you have not reinstalled your tow hooks. I cut out the plastic under where the frame sticks out, to put the hooks back on. I got to thinking that the plastic matches the bumper, and was roughly the same size as the frame pieces. I did some trimming to get the cut out pieces close to the right size, and then removed the back (i guess support strips, or ribs) . I used a utility knife. I then heated up the plastic so that it could be straightened, but left the lip alone so that I could use it as a contact point. I had some household multi purpose cement, I guess epoxy would work unless you need to take these covers off. I put alot of the cement on the lip of the cut off pieces, and applied them so that the lip was on the bottom of the frame piece. I tucked the top of the pieces behind the bumper. I propped them in place with a couple pieces of scrap wood, and let it sit for several hours. Like I said, I did it yesterday around 5 pm, and they are still stuck on after a day of my wife driving the truck. I you have any questions, respond good luck. chris
