Lift Questions!
Check out this link , these blocks are angled .
http://www.truckin-richmond.com/prod...&search=blocks
Thanks for all the help! I knew about the add-a-leafs from a few other posts on this site! thanks for the suggestion! I guess what I am looking to do is this, Right now when I look at my tuck from the side, the front sits higher than the rear! when I look at a few other F-150 the rear is higher than the front! So I am thinking that the leafs and shocks need to be helped out and replaced! New Monore sensa tracks are going to replace the shocks and I am goign to check out J.C Whitney for some add-a-leafs! if that doesn't help then I am going with the lift blocks! What do you guys think!
