2" leveling kit, tires wearing out
Hello all,
I have a '13 Screw 4X4. I installed a Hell Bent Steel 2" leveling spacer and got an alignment at the dealer. The outer edge of my tires started wearing very fast. I rotated the tires and got another alignment at Discount Tire. They said the wheels are aligned perfectly but couldn't explain the tire wear. The tires continued to wear. For giggles, I took it to yet another alignment shop. They said the toe was off very, very slightly. Again, I was told it wasn't off enough to cause the tire wear.
I love the look of the truck leveled but not enough to keep going through tires. Any suggestions?
Thanks folks...
Thanks folks...
Typically, toe in condition would cause rapid outer tire wear and I would think multiple alignments would insure that is not the case. Excessive positive camber would wear outer fronts as well, although not very quickly. This would be easy to determine by naked eye because your front tires would appear to be tilted out when wheel is straight ahead as viewed from front of vehicle.
A potential is could be the lift caused a significant change in geometry and the outside tire is turning a smaller circle than designed and as a result scuffing the outer edge.
You basically need a better front end mechanic to diagnose.
I did the Rancho Quicklift Loaded's, and new BFG Rugged Terrains almost 50k ago...had it aligned at the same time...I have had nothing but alignment problems since...toe in was the worst part causing the tires to scallop on the inner edges...I have had 2 alignments since ...I am almost ready for my next set of tires...what are the differences from the factory specs would a tech need to change?
I am running Stock size LT275/65/18...I had 3 sets of tires previously that they all wore evenly...no alignment problems up to 128k miles...
