Best HD rear shock for towing 2014screw
Hey guys,
Im looking to upgrade the factory rear shocks on my 2014 F150 4wd to something more suited to heavy towing applications. I am looking for something with a decent to long life span and will hold up well to a heavy trailer behind the truck.
Any thoughts?
Thanks in advance!
-Dennis
Any thoughts?
Thanks in advance!
-Dennis
Thanks for all the responses!
My work trailer is a 20' kearny trailer that weighs about 2500 lbs. It likes to bounce depending on the load and I really just want something that will deal with the strain.
If you are hooked up a lot the 9 is a good choice just for the ability to "firm" up the rear.
Again good luck!!!
Again good luck!!!
have you thought about using the Firestone Ride-Rite leveling airbags? they bolt up between the leaf packs and the frame and pretty much absorb most of the weight of whatever you're towing/hauling so your rear suspension doesnt get beat up as much. also they level out your truck for added safety while towing. i had them on my 05 F250 Powerstroke and i liked them so much im getting them for my '13 F150.
https://www.stage3motorsports.com/25...pring-Kit.html
