Lift Kit Question
Old 09-02-2014, 05:52 PM
ninjaguy's Avatar
Lift Kit Question
So I've tried looking for the answer to this but couldn't find anything. Would a lift kit for a 09-14 f150 fit on an 07? I wouldn't think the suspension components would be that different but I could be wrong. Thanks
Old 09-03-2014, 10:21 AM
EsJayEs's Avatar
Depends on the kit itself. Can you be more specific?
Strut spacers and rear block kits will fit the same, but some things may not. The 04-08 used leaf springs that are 6" shorter in the front-half, the lower control arms are aluminum on the 04-08 (but they may be interchangable - not sure), and the shocks and struts are a little shorter as well.
Not to say a kit won't work, but need specifics. What kit are you looking at? Is your truck 2WD or 4WD?
Old 09-07-2014, 06:28 PM
ninjaguy's Avatar
It is the rough country lift, it's made for a 2wd and my truck is a 2wd
Old 09-07-2014, 11:50 PM
EsJayEs's Avatar
Would require more parts to make work. The front wheel bearings are a complete hub assembly on the 09-14 2WD trucks.
Quick Reply: Lift Kit Question
