Need help
Can you please help
Hey guys I have a 2006 xlt 4.6L 2wd extended cab. I wanna lift it but everyone tells me I shouldn't because it's a 2wd. So what else could I do? Should I add spacer so it is a little wider and a leveling kit? What is the biggest size tires can I get without rubbing.
Should I not lift it and just get bigger tires and shouldn't that bring it up a little?
And if I lift it how much should I
Lift it?
Lift it?
Lift it if you want too. It's your truck.
If you want a 6" lift and only go with a leveling kit, you'll most likely be unhappy and still want to go bigger.
If you go with a level, a 33x12.50 or around it's metric equivalent will work depending on tire tread aggressiveness and wheel width. If you go bigger, say a 6" lift, then you'll be able to do 35x12.50's and most likely be able to clear a more aggressive wheel width and offset without rubbing.
