Major bump steer????
Old 07-27-2014, 08:42 PM
rpm0024's Avatar
Exclamation Major bump steer????
I'm having major bump steer ever since I added my leveling kit the other day, does anyone know a way to fix this is there anything I can adjust that will help control that and get it tamed down?? I still have yet to get it aligned since I couldnt get it done on a sunday so I'm hoping that may help some.
Does anyone know if theres a leveling kit that levels the suspension rather than just spaces out the strut??
Thanks for your time and the help.
Ryan.
Old 07-27-2014, 10:12 PM
pizzaman711's Avatar
Get it aligned. That'll help greatly as long as you didn't go crazy with the size of the leveling kit.
And if you want to get good angles again (I assume that's what you mean by level the suspension) you'll need to go to a full suspension lift with drop down crossmembers or get a body lift and put the angles back to stock.
Nevermind, just saw your other thread about doing a 3" level. Good luck getting it aligned properly. That size of a level and no alignment would definitely explain all the bump steer.
Quick Reply: Major bump steer????
