Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 08-22-2001, 07:40 PM
Garage is empty, add now
Droppin the Harley
Ok..so ive looked at the SoCal kit and its insanely expensive ~$800 dollars~ and ive looked at the BellTech kit which is less than half the price but seem to have a problem with the Harley F150 and not getting along with driveshafts very well.
I have heard from 2 people now that have had driveshafts bent after installing this kit.
Is this due to a bad installation? Defect in the kit since the harley truck is already lower than a stock F150 but Belltech just makes an F150 drop kit?
Does anyone have any other options for lowering the HD truck to have only 1" of fender clearance?
TIA
Brian
Old 08-23-2001, 02:46 AM
Vehicle: 1999 Ford F-150
Send a message via AIM to 99flareside Send a message via Yahoo to 99flareside
I have had my Bellltech drop for about a month now with NO problems! But then I do have a regular cab The Belltech comes with axel shims to correct the driveshaft angle after lowering, maybe those other guys didn't put those in! Or you could look into Western Chassis drop kits http://www.sporttruckdirect.com/
1999 F-150 XLT 4x2
4.6L V8 5 speed
*Gibson Super Truck
*Hurst shifter
*MAC intake
*Street Scene valance
*Stull billet grilles
*Belltech 3/4 drop
*20" Boyd Coddington Nemesis'
*Goodyear GTII 275/45/20
Old 08-23-2001, 12:48 PM
Vehicle: 2000 FORD F150
I have the Bell TEch 3/4 lowering kit in my 00 HD Ford, and was one of those that had to replace a bent drive shaft. After another company corrected the "angle" with an axle shim, I have not had any other problems, except for the "rough" ride. I have had one quote for approx $5000.00 for a "top" 4 link air system, and am now looking into the possibility of "C" notching the frame.
Would appreciate any comments from anyone who has had either of the above work done.
2000 HD FORD
HOLLEY "THUNDER" SC
JBA HEADERS
FLOWMASTER SERIES 50
99 FLHTC-UI HARLEY
Old 08-23-2001, 01:56 PM
So the original install of the Bell Tech kit was done improperly?
Well if thats the case then that sheds a new light on the subject
Ill check out the wester chassis kit too. Thanks for your input.
Old 08-23-2001, 03:25 PM
Vehicle: 2000 Ford F-150
i dont personally have any experience with dropping the full size fords, but i do have some experience in lowering trucks...most reputable manufacturer's put shims in the lowering kits once they reach a certain drop...the purpose of the shims is to correct the angle of the driveshaft...the only thing that should happen if you dont have the shims in would be a vibration...
as far as the lowering kit goes, if the HD is lowered 1" from the factory, and you put a 4" lowering kit on it, the truck will still be lowered 4", not 5"...the lowering kit would be a 4" drop from the factory height...
dont know if this will help any or not...
scott
Old 08-23-2001, 05:28 PM
Ahh..that does clear some things up.
This also makes me wonder whats so special about the SoCal kit for the HD F150?
Ohwell, Guess ill go with the belltech.
Old 08-25-2001, 03:22 AM
Vehicle: 2004 Ford Expedition
No, the HD 1" is lowered with springs.
Add a drop spindle of 4", that make 5"
Old 09-06-2001, 02:23 PM
i didnt realize that they were lowered using springs...you are right in that case...sorry about that...
Scott
pingletonsb@yahoo.com
2000 F-150 XLT supercab short bed
5.4L 4x4
black/tan/tan
Westin step bars (black)
Old 09-13-2001, 01:56 AM
Vehicle: 1998 Ford F150
Wow, 5,000 grand for a airbag setup. do what i would do if someone qouted me 5 grand for a airbag set up. SMACK THEM IN THE HEAD! and if you even think about it, smack your self.
Airbag setup for a ford is quite expensive, and you have alot of work ahead of ya, but if its anybody who knows what they are doing, then you wouldnt pay more then 3k. i got a full setup for 3k, bags, 2 100% runtime compressors, 1/2inch lines, all 9 switches mounted in a Playstation remote control, 2 link (got 2 link over 4 so i could do side to side better) for just under 3k.
also, if you go as low as i have, you will have to notch the frame. (i went 6 inches) you will have to **** with the Tranmission mount ( you will drag it lots and often, i already broke mine 3 times) and you will have to notch the bed frame rail in the middle if you want to ride all the way down cause your drive train will rub.
so what have we learned?
Drops good, Bags better
draggin ground makes neats sparks but your transmission bracket suffers
if your going fast enough and low enough, you can scrape up reflectors in the middle of the road
always ride with your front end up if you dont have spindles cause you will wear the inside of your tires out (ouch there goes a new set of yokahamas)
if your bed rail frame is not notched, dont ride all the way down cause you will totally tear your driveshaft to peices and it makes a really funky noise.
Chicks dig stuff low to the ground.
1998 F150 XLT
9 / 11 inch drop
6 inch c-notch
Full Firestone Airbags
1/2 inch Hoses Hardline
Front/Back Side/Side Valvues
AirAid Cold Air Induction
Poweraid Spacer
Bored Out 4% restriction Flowmasters
Transmission Bracket Flipkit
Full Ladderbars 4 bar setup
Kenwood 7011 Reverise Face CD
Kenwood 1000 Watt Amp
Kenwood 12 disk CD Changer
2 12' Kicker Impulses
Custom FiberGlass Box
Playstation 2
17 inch Enkei RTS w/ Yok's Z rates
Blue 1/2 inch and 1/4 inch Wire Loom
Blue Hood Light Water Squirters
Blue Indaglo Dash
Blue Indaglo Peddles
Blue Indaglo License plate holders
Blue Bored 9360 Bulbs in Brake housings
F-150 Indaglo Blue Oval Decal
3rd place winner of Texas Heat Wave for Fullsize Ford Street Class
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
