All inclusive Do's, Don'ts, Common Lift Questions, etc.
#31
There is one thing I'm still confused on, as I'm pretty new to lift kits and all, when y'all say "don't buy aftermarket torsion keys" is that the same as a leveling kit?? Cause when I look up leveling kits, it seems at though they come with new torsion keys? I may be wrong, but can someone help me out a bit as far as the difference between the two?? In other words, is a leveling kit the exact same thing as cranking the torsion bars?
#32
You can crank your stock torsion bars for free and level the truck and still be within spec.
Aftermarket torsion keys, also known as leveling kits for the 97-03 4x4s, cost money, and allow you to crank too far putting you out of spec, meaning it puts your ball joints, tie rod ends, and cv axles at terrible angles causing them to wear out extremely fast and it makes it pretty hard to get a decent alignment.
#33
I know it has the aftermarket keys, but would it be SAFE to use these types of kits as long as I don't crank the keys so far that my front end is out of spec??
I'm sorry for all these similar questions, i feel like an idiot but I don't wanna screw up my truck!
#34
Technically it could be, if you knew where to stop. I'm just not seeing any reason why it'd be worth it to risk it. You can pick those shocks up for pretty cheap as well as a rest block if you want the rake back, if you want level a block isn't even needed. But if your buying if just for the block and the shocks, buy them seperate, you'll save like 40 bucks.
#35
#36
#37
Since you have struts you can leveling struts and adjust those to the height needed to level or go with a leveling kit.
#38
#39
Stock length shocks should be fine, but if not you might be able to find some for a 2" lift from someone like bilstein, procomp, fabtech, rancho, etc.
#40
#44
#45
